Nicholas A. N.
- Jan 15, 2003
I just got online for ps2 and xbox and i was wondering what games to get. I only want suggestions that aren't football or major leaguue sppports.
asshats
It is so simple that you can be killing people online in a few minutes.
we can add Burnout Revenge as a great online PS2 game.Xbox as well, no?
Another title if you dig racing is MotoGP 2 - one of the slickest, best live experiences out there.It's also hard to find. Used copies will run ~$30-40, and factory sealed ones can command $60 and higher (applies to the Xbox version only).
[MotoGP2] is also hard to find. Used copies will run ~$30-40, and factory sealed ones can command $60 and higher (applies to the Xbox version only).It's out of print? If you're interested in MotoGP (amazing as indicated above, online and off) I just noticed that MotoGP3 is now out. More of everything it seems. And from a quick glance it looks like it's pulled a page out of Project Gotham 2's book for merging offline and online play (stats, for example).
X-Men Legends II is said to have online co-op which sounds like it will kick ass. Plus you get to fight Apocalypse, what's not to like?It also has some serious online implementation issues including restrictions on what resolution and television standard you're playing at. So if you are playing on a widescreen TV (with widescreen enabled in the dashboard) and 480p, while your friend is playing on a regular 4x3 standard set; you won't be able to play with each other. You will need to turn off 480p and widescreen in the dashboard to play with your buddies. Works the exact same if you are playing in 720p (the game does support it).
