Mike_Ped
- May 16, 2001
Ok, while drilling the holes for the driver in the bottom endcap of my sonosub (2, 3/4" thick MDF and 1, 1/4" plywood glued together)I had a slight mishap! Of course, with my luck it happened on the last hole. Well, it takes a lot of pressure to drill all the way through the endcap and I guess I lost my balance a little of the way through which caused the drill bit to go through THE SIDE of the wood. To paint a better picture, it looks like I have a groove dug out the side of the driver hole! DAMNIT! How do I go about fixing this?? I filled it with wood filler but I really don't think that will work when I go and try to drill a hole through it. Any suggestions in making the repair in the wood? THANX in advance!
Mike
Mike
