Scott Merryfield
Are you speaking of the Sony UBP-X800 4K Ultra HD Blu Ray player? If so, how would you compare this device to an Oppo? I am certain the differences are day and night; but curious as to how you might measure or rate it all.
I don't have the Oppo UHD player, so cannot offer a direct comparison in picture quality. The Sony does support both SACD and DVD-Audio discs like the Oppo, but lacks Dolby Vision support. The Sony does an excellent job upconverting SD-DVD and BD material to 4K, IMO. I let the player do all the upconversions instead of my Vizio 4K display. The Sony is substantially less expensive than the Oppo. I have experienced an occasional player freeze-up when playing UHD discs, but ejecting the disc, re-inserting it, and resuming play fixes the issue. The newer Sony X-700, which is supposed to eventually get a firmware upgrade for Dolby Vision support, has had a similar issue reported elsewhere, too.
I am planning on eventually upgrading the Sony to either the Oppo or one of the new Panasonic players for Dolby Vision support, and moving the Sony X-800 to our bedroom where the Samsung 4K display is located. I do not need Dolby Vision support there, and the current BD player attached to that display is an early model Sony which is quite slow loading discs.
