Calling the Service Mode:
Holding down the MENU button on the TV set front, turn on the power button on the TV set.
To Exit the Service Mode:
Turn the television off by pressing the power button.
Dave
Thanks Dave!
Now all I need is to figure out how to use it.
I've used the Toshiba service menu counless times in the past, but this totally different.
You type in a 3 digit code and press Input on the remote to access the value associated with that code. The problem is, I have no idea what each 3 digit code corresponds to.
Anyone have a chart or cross-reference they could share? (Dave? )
Thanks.
-Mike
Send me you home address through my e-mail and when I return to work around the 14th of Jan I will make a copy of the info that you are seeking and mail it to you.
