BrandonP
- Oct 27, 2002
I have a GeForce 3 that has a VGA and an S-Video output on the back....the VGA I use for the monitor obviously and the S-Video isnt being used.
I do have a VGA input along with all the usual inputs on the back of my 55" Mits.
I have heard a direct VGA is a very good way to do it without lots of converters and what not but I believe that my computer has to be in a certain resolution or something to get it to display on the TV.
Should I try to use the direct VGA to VGA or get a special cable to do it a different way?
Also if I do use the direct VGA to VGA is there anyway to split it so that I can use the Monitor and the TV without manually switching the cables back and forth?
Thanks for the help gang!
