GaryJ
- Oct 30, 1999
Hi:
I have built a rather large wall unit for my family room. The unit is 8’ tall 12’ wide and 28” deep. I have left the bottom area open from 18” down and covered the front with speaker fabric. My original plan was to put a couple of retail box subs in there but am thinking I could build in a couple of neat subs in that space. The spaces in-between the supports are approx 18”HX24”WX28”D. I have never built a sub before but I did build the unit so I have some woodworking skills. I am planning on using a 15” Tempest driver and a 250W plate amp. Here are my questions.
Do I just close in the area and use all the space as a box and mount the sub in the front and the amp in the back.
Are there particular volumes I should be looking to create?
Am I better off building a box that fits in the space to avoid coupling of the sub to the wall unit?
Any other advice would be greatly appreciated.
The sub(s) will be working with Acoustic Energy Aegis One speakers. The room is 3200^3.
Gary
Gary
