Fred G
- Apr 16, 2002
I'm currently using a Magnavox HTIAB sub with an Onkyo receiver. Soon my Fluance speakers will be arriving and I was thinking of getting another sub to go with the Fluance speakers. But I don't know if I will get better performance by getting another sub, or if I should just stick with the HTIAB sub. This sub certainly gets loud enough and actually I have it set to -4 because I don't want to disturb the neighbors in my apartment.
Admittedly I don't know how to interpret these specs so I don't know how this sub compares to others in the same price range.
Sub specs according to manufacturer:
Subwoofer ……………………………. 6.5"
Output power ……………………..…. 75W (4 Ohm, DIN)
THD …………………………………..10% at 80 Hz
Reproduction frequency response …….30 Hz - 180Hz
Phase switch …………………………..0°degrees, 180°
Input sensitivity (Subwoofer In) ……….200mVrms
Power consumption ……………………53W (at 1/8 rated power)
Weight …………………………………17.2 pounds
If I was to replace this sub I'd be betting one of the $150 subs available.
Dayton 10"
VELODYNE ACOUSTICS VX10 (jandr.com)
Sony 8" sub (bestbuy.com)
My most likely choice would be the Sony because of the price. How would the Sony compare to the other two. Would the _quality_ of the bass be very much different than the Velodyne and the Dayton? "Quantity" of bass is certainly something I don’t want nor do I need, but if the quality will be better I may consider not getting the Sony.
So is it worthing getting a new sub, or will the Magnavox be just as good for my purposes (playback at mostly low to moderate volumes)?
Dayton 10"
