Bart_R
- Nov 25, 2002
Hi everyone,
I recently purchased a (second hand) mordaunt short center speaker (905c), but I'm not satisfied with the higher frequencies. It sounds too harsh and peaky at times, imho. I've been using all sorts of different settings and connections to try and solve this, but nothing works.
I'm thinking now about building something into the speaker that will block the highest tones from going to the tweeter. I did some reading on the internet, and it seems like I need either an inductor or a resistor. It's still not clear to me what should be used. Can somebody help me with this? What would I need? Also, does somebody know of a site that tells/shows you how to insert such an inductor or resistor?
[Also, is it worthwile to do this and can it be done to begin with by a non-professional (I mean, I can have it done by this store, but that will cost me...).]
