On my X4300 I see at place to hook up a CD. What about a cassette player, a VHS, and a Beta? Not sure where to put those. I hardly use them, but I wan't have them hooked up because I want to sell them and be able to demo the devices.
I thought that would be the case. Does this go so far as to let me use, for instance, Audio In 1 (labeled cbl/sat) for the cassette, and the HDMI 1 input (labeled cbl/sat) for different devices?The cassette deck outputs can be connected to any of the receiver’s Cbl/Sat, Game, Bluray or DVD audio inputs. You will not be able to make connections for “record” on the cassette deck, at least not easily.
The audio outputs of the VCRs can any of use the same connections, and their video outputs can be connected to receiver’s Video In for Cbl/Sat, Game, or DVD.
Wayne A. Pflughaupt
I dug out the manual on the 2809 and on page 12 is says:I'm no expert on these things, Johnny, but I would guess the issue you are having is that the old and new receivers probably are not communicating with each other via the HDMI connection you have established between the two AVRs. I am not sure if doing such a thing is even possible -- each receiver is expecting either a source component or a monitor attached to the other end of those HDMI connections, not another receiver.
Do you have a pair of extra speakers laying around? If so, I would just use those to demonstrate the receiver works. I know it will not demo all the speaker outputs, but it should be enough to convince a buyer that the device works properly.
I just ordered a Denon X3300W to replace my 8 year old Pioneer Elite 94TXH. I am not sure what I am going to do with the old Pioneer yet. It still works well, but the HDMI 1.3a inputs are outdated for anyone wanting to move to a 4K setup. So, I am not sure it's even worth the bother of trying to sell it, which is a shame because it was a superb AVR for a 1080p setup.
To output the audio signals to the monitor with HDMI connections, set menu "Manual Setup" - "HDMI Setup" - "HDMI Audio Out" to "TV" (Page 29).
I don't believe I checked this last night. My day is busy until after 1pm, so I'll check it then. This may explain why there's no audio out for either hookup arrangement I tried.
In the manual, on page 29, it shows the selection as "AMP". In this setting, what happens?
If I change the setting to "TV" does that shutoff the sound to the speakers? I think it does.
This explains the problem, I think. I'll bet the setting is AMP.If set for "AMP", the receiver will pass only video (no audio) out through the HDMI connection to your display attached to the monitor HDMI output. If it's set at TV, then both audio and video are sent out via the HDMI monitor out connection.
Yeah, let me know what you get.You should be able to plug the line cord into either the right or left input of your subwoofer -- it doesn't make any difference which you choose.
It's interesting that Audyssey wanted you to crank up the volume level on your subwoofer. With my Pioneer Elite's MCAAC auto calibration, the software kept asking me turn turn my subwoofer volume level down until it was in the 7-8 o'clock position (with 6 o'clock being off). I will be interested to see what I get with Audyssey on the Denon X3300 when it arrives.
When I reran Audyssey (couldn't they name it something easier to spell), I refused to set it as high as it wanted and the calibration went fine.My Denon X3300W arrived yesterday, and I spent this morning getting it installed and configured. My subwoofer volume level ended up very close to where it was with my old Pioneer receiver after running Audyssey -- around the 7 o'clock position again. It certainly did not need to be increased like you experienced with your sub, Johnny.
Isn't your subwoofer volume too low by doing that? Or did Audyssey compensate for your adjustment?When I reran Audyssey (couldn't they name it something easier to spell), I refused to set it as high as it wanted and the calibration went fine.
Scott,
Did you set up Dolby Atmos? If so was it difficult?
It's CakeDid you set up Dolby Atmos? If so was it difficult?
Sam,It's Cake
And yes, in general Atmos tracks even without real or fake height speakers sound better than stock DD or DTS to me
I'm adding my 2 upfires to my 3300 tonight. Will be easy and should sound way better than the similar setup in my office with a 2200 and AJ integrated upfires
