BrianShort
- Jan 18, 2000
Finally got around to hooking my PC up to my 42" Sony A10. Just used a cheap VGA cable I picked up at the store. Didn't hook up audio, as that metal plate on the back of my case, where all the jacks and ports stick out, is blocking a coax cable from being firmly inserted to the SPDIF jack, and I'm too lazy to fix that right now. Anyway, looked really good. My question is, would using a DVI to HDMI cable work better than using the VGA, or does this set require a computer to be hooked to the VGA computer input?
Brian
Brian
