David Nolan
- Mar 9, 2002
good morning all,
i have a harman kardon avr-525 that has worked wonderfully for the past 6 months or so, until last night. i dismantled my old a/v cabinet and removed all of my components in order to install my new a/v stand. everything was turned off and unplugged before connections were made/unmade. then, once everything was reassembled, the 525 was not so right anymore. my "on" volume has always been set at -50db, and normal tv viewing was around -45db. after the reset, i have to turn up the volume to -30db to get the same spl reading that i used to get at -50db. and this is on all of the inputs, regardless of source material. but then the really weird part is the dvd input plays everything at full volume (like 0db)regardless of where the volume is set - and on both the optical and 6 channel inputs. the test tones come out the same as the other inputs - softer than they used to be, but not blaring. i tried unplugging and waiting, even tried the full reset, nothing helped. i'm wondering if i am missing something. there are no night modes enabled to make the other sources softer - and no rock concert modes enabled on the dvd. i've moved my equipment around many times before and never had anything like this happen. if anyone has any advice i would appreciate it. i have some family members coming this weekend and i was looking forward to demo-ing/showing off my set-up. the receiver is still under warranty, and i bought it from one call, so i'm not worried that i'm stuck with a lemon, just frustrated that i can't fix the problem. thanks in advance.
david
david
