Keith>R
- Aug 12, 2004
My family is looking into installing a home theater system. After searching for quite some time we finally found a reputable dealer that we feel comfortable with and that we know will do a good job. We are still at the stage of deciding whether or not we should go ahead and have them install it. They came out and gave us two identical estimates except for the projector used in each. The lesser estimate uses the Sony VPL-HS20 and the other uses the Sharp XVZ10000U. Now, money isn't really the issue, we can go ahead and spend the money for the Sharp. However, because of the unique space we are using for the system the largest reasonable screen we can use is a 70" diagonal 16:9 screen. So, my question is, is it really worth it to spend nearly $5,000 more on the sharp in such a small screen format? Will the differences in the two units still be that substantial in this case? I have read really good things about the Sony on projectorcentral.com so I'm unsure of how to advise my parents. I would appreciate any input you have. Thanks,
Keith
Keith
