ScottHH
- Oct 24, 2002
'what do I need'?
All of the Sony tube's you are looking at have a 1080i display. They are all capable of displaying a hi-def picture.
If you are receiving your hi-def off-the-air you need a tuner to receive the signal, it is the 8-VSB tuner. If you are receiving your hi-def via cable, you need a different tuner to receive that signal, it is called QAM. Without these tuners, you have an HD-ready set. If they're included it's either HDTV built-in or an "HDTV"
If you had a tuner to receive either or both of these signals, or when you have an HD-DVD or Blu-ray player, they are at this point most likely going to output via HDMI. Once again all of the Sony TV's you are looking at have an HDMI input. Here is Sony's explanation: HDMI Interface (High-Definition Multimedia Interface) provides an uncompressed, all-digital audio/video interface between the TV and any HDMI-equipped audio/video component, such as a set-top box, DVD player, and A/V receiver. HDMI supports enhanced, or high-definition video, plus multi-channel digital audio.
There are some copyright issues with HDTV via component cables, and the common believe is that the must future-proof option today is HDMI with HDCP. I don't think this is an issue you need to worry about as long as you have an HDMI input.
