Mark Danner
- Nov 13, 2003
Well I have decided that it is time to shop for some speakers. The system would be used for 70% movies/x-box games and 30% music. I am looking to spend $1000 - $1900 ($1400-$1600 would be great). Would you recommend no sub if I share one wall with a neighbor (nobody above or below)? The room is 19'4" (front wall) & 15'4" (side wall) with a 9' ceiling. The receiver is a Denon 3802. Here is what I have planned so far for shopping:
Store 1
B&W 300 series (I know it has a sub)would it be a better system by not getting the ASW 300 and getting an SVS PB1-ISD? Is the 300 series too small for the room?
B&W DM603 s3, LCR 600 s3, DM600 s3 with no sub.
Is there a better mix and match with B&W like going with DM601's instead of the 603's and the LCR 60 with the SVS PB1-ISD?
Store 2
Paradigm dont know much about them or their different speakers. Where is a good starting point with them? I noticed that their cheaper packages include speakers rated to 80 watts. My receiver is pushing like 105. Should that be a concern?
Also you guys have me intrigued by these Rockets. What would their comparable models be? Their packages sound good but now sub for those small speakers. Will I be disappointed in them with no sub? Also, how would you compare the Rockets sound tendencies to the ones mentioned above? (for ex brighter, more mellow, etc.)
Any other suggestions on how to shop for speakers (what to bring, etc)?
Sorry for the long post and thanks in advance for your help!
Store 1
Store 2
