jheiser
- Apr 22, 2010
- James Heiser
Selden- Yes, the front left will be just left of the screen and just right of the slate and stone for the fireplace. The right will be just to the right of the screen. I would like to mount the center directly under the projector screen and a few inches under the TV. This will be just ear level practically with the viewer. Yea I figured not having everything rectangular or square would present some sound problems. Is there anything you did to fix this? Or is there any ideas to re-organize the room?
Yea that's exactly what I was thinking. I can deal with the imperfections and possible come up with some sort of rig to tighten the screen when viewing.
Would I have any issues with having the futon against the wall? If so, I'm thinking I'll just pull it about 3' off the wall when watching movies.
