Does anyone know where I can get a disc called "Video Essentials". I understand it is for adjusting and set-up of HDTV. I already have the "Avia" disc. Thanks, DR JOHN
Also, HERE and HERE. The latter also sells the 6500K color temp bias light if you've ever thought about it or want to see what it's about.
I read that this (1996-97) disc is out of production. Has is been recommended to you? I find AVIA does the job for me, altho I do not own an HDTV.
After about 100 hours on your HDTV, it's recommended by many to contact an ISF technician to professionally calibrate your device in-home. Cost ranges from $300 to $700.
bill
I've used both VE and Avia, and find Avia much easier to use and more comprehensive, particularly on audio issues. Besides, as was said above, VE is no longer being produced, and its replacement, Digital VE, is long delayed.
