Hap C
- Nov 11, 2002
In trying to decide between a B&K AVR-505 (3 HD capable component vid inputs) and a Rotel separates combo, which includes the RSP-1066 (2 HD component vid inputs), it struck me that while I thought the B&K had a slight advantage, it would be easy to need more than 3 HD capable component video inputs so that the B&K did not have enough. I currently have 3 HD inputs (HD terrestrial receiver, HD cable, prog scan DVD), but if I add anything else, say an HD digital recorder, even the B&K will not have enough inputs. Then you're off to using outside switchers, like the Audio Authority 1154. I'd like to avoid that if possible, and do all switching through the receiver or pre-pro.
Here are my questions:
1. How many component video inputs are "enough" taking into account all sources one might reasonably expect to use over the next 3-5 years? My vote would be for 5, but I know nothing about games, etc., that might require component inputs.
2. Why do all the manufacturers seem to think 2 or 3 is enough? Am I missing some obvious logic there, or are they just way behind in understanding current consumer use? The only component I have found with 4 is the flagship Marantz receiver, the SR-9200.
3. Finally, why do manufacturers persist in putting 6 essentially useless composite vid inputs and 6 S-video inputs on most of the better components? Is anybody really using that stuff? It takes up half the back of a receiver, and who knows what amount of circuity in side. Maybe it's just cheap to add it, and they do it for that reason. I have a VCR plugged into 1 composite input/output, but other than that they are all completely empty. Is this something done for foreign markets?
Cheers, and looking forward to your comments.
Hap
Hap
