Hi all, I have a Viera P60ST60, Denon 1713 AVR, and a Motorola PVR (DX3400) for Time Warner Cable. This is a completely new setup besides the PVR (I used with an old TV for a couple of years and never had a pink tinted screen before with it, so I suspect it isn't the problem).
I turn the setup on via a Harmony One remote and every few days it turns on to a pink/purple tinted screen. I've turned off each unit separately when this happens and then turn them back on and the screen will stay pink unless I turn off the TV. Turning off and on the AVR/PVR separately doesn't fix the problem. I shouldn't have done this, but I left everything on once and unplugged the HDMI from the PVR and plugged it into my DVD, fired it up and it was not purple/pink. I kept everything on and unplugged it from the DVD and plugged it back in to the cable and it was pink/purple on the cable again. I thought that was particularly odd.
I haven't done much other in the way of troubleshooting, but I did read on this forum to prevent handshake issues, unplug everything from the wall and plug it back in. That seemed the most promising as its been nearly 2 weeks since the last episode (before it was occuring every 2-3 days), but alas, last night I turned it on and it was pink/purple again. Any idea what this could be or what I can try to do to fix it? Could it be a malfunctioning TV/AVR/PVR?
