LeoA
I have a variety of different tv sets with defective cases in need of replacement. I've long dragged my feet with quite a few damaged sets that have sat for years, and finally went looking tonight. I discovered high prices and several styles of cases that I couldn't even locate.
One I'd need a couple of replacements for and failed to locate are what Shout Factory has used in recent years for their tv season sets. They're the cases that have dimensions similar to a single disc DVD case, usually with translucent plastic, but have hinged pages inside so as to accommodate 5-6 discs.
Another one I failed entirely to locate are these slimline cases like used to be common with tv season sets, usually also in clear plastic, that fit one or two discs to a case. The two disc versions especially seem fragile. A lot of my Adam-12 and I believe Emergency! sets came in these for instance with prongs that were snapped off or simply ineffective at securing the DVD right out of the shrinkwrap.
One that I actually found a replacement for but seems priced high is linked below. Is there a better source than this? It doesn't need to say 4k Ultra HD (A normal Blu-Ray case would suffice). It's for the Peanuts Holiday Collection, which I bought recently but discovered oil is seeping out of the plastic and getting on the playback surfaces of the discs (I'd clean it, but assume the cheap plastic will continue to outgas).
Is there a go-to site out there that people go to when they have cases that require replacement?
