Pat K
- Mar 15, 2002
Im looking for a good, DTS receiver for under $400, hopefully at least around 70w per channel. Also, wheres a good online store to buy stuff like that cheap? Thanks
The Kenwoods are THX SELECT, which is not the same as THX CERTIFIED. I would not go with one of these, but that is just me.
Methinks you are mistaken. Select and Ultra are forms of THX certification. The most accurate way to describe the Kenwood 510 would be to call it THX Select Certified. I took the following information directly from the THX website:
Manufacturer: Kenwood
Category: Receiver
Model: VR-510
Status: Certified
Region: USA
Special Notes: Dolby Digital/DTS
Type: Select
Perhaps you were refering to something else? If not then I am interested in the differences.
However, oddly enough, the Kenwood 510 has had some issues with Dolby Digital audio dropouts of a few titles just like some of the Onkyo models have. This only pertains to the 510 however. The rest of Kenwoods line seems to be uneffected.
Dan Hine
If you listened for yourself, and I think you would be too.
I happen to be a Kenwood dealer. I do like Kenwood a lot. And the 510 does offer a lot for the $$. But if I were installing a large size theater then the added power and lower distortion of the 4802 would be more appealing to me...as well as the built in amp for rear channels.
But yes, I do agree that the Kenwood 510 is a solid performer, DD dropouts aside.
Dan Hine
