Matthew Cook
- Jul 7, 2004
Ok I have got a problem, if I wasn't bald I would be pulling my hair out. Ok I have been looking for a wall sconce, first off it has to be a spotlight kind of a sconce that is pointing downward. When I was cutting ot the hole for the sconce back in the beginning days of this project I cut the hole rather high. From the top of the hole to the ceiling it is 8 inches. So you see my problem can anyone help out? It has to be cheap I know it is not the best term to use on this forum but I am tapped after the cost of building this project. I need 4 my budget it around 100. I looked on ebay for hours with no luck I thought about getting some sconces and just flipping them what do you think about that?
