HI,
First let me say, what a great site! I have spent the last couple days reading all the posts, and especially appreciated all the posts regarding what people would do different if they had the chance!
Let me give you a break down of my Room Setup... Then I'll ask my Q's... (if thats alright)
My room size is limited to 12ft 6" (wide) by 17ft (deep) it is in the basement of my brandnew home so the floor will be concreate. The entire area is an empty shell at this point and I am in the process of Design.
In order to get the best out of the situation I have I wanted to ask these relatively NEWBIE Q's.
1. My Ceiling is only 8ft high (plus it needs to be fininshed Drop, or Drywall which will bring it down another 3"), and all along the one side I have duct work spaning the length of the room (17ft long) and about 3 1/2 (wide)... The height under the Duct work floor to Duct is only about 7ft (maybe little less...
My Question is in a room this type what would be the ideal location for the PROJECTOR... Right at the back of the room, or closer to the middle... Is farther away Better or worse...
2. THE SCREEN... I would like to create as big as screen as possible alone the 12ft 6" wide wall. What would you guys recommend keeping in mind that I need to place the speakers on each side of the screen (stage) and dont want it to feel cramped... Any suggestions on screen size?
3. Whats the deal with buying a HT screen compared to making one out of drywall yourself? I know the costs savings are there to create your own screen, but will I be jeoprodizing quality in a major way?
My biggest concern is the projector setup... Do I have enough height in the 8ft ceiling to work in a room that I have described..
Thanks in advance for your help!
Cheers
Cheers
