Jeff Harlow
- Aug 6, 2002
I have a Sanyo PLV-Z2 for sale. Unit is in great shape, only a few months old and has no stuck pixels or other issues that I am aware of. This is the best HD projector deal on the market and the lens shift feature really makes it easy to install which can be a big deal for other projectors. Asking $1550 shipped.
Product Specifications
Native Resolution: Native Widescreen HDTV (1280 x 720)
Lumens: (brightness) 800
Weight: (lbs.) 9.0
Dimensions: (inches) 14.1(W) x 10.8(D) x 3.8(H)
Zoom & Focus: Manual
Contrast Ratio: 1300:1
Aspect Ratios: 16:9 Native and 4:3
Lamp Life: 1500 Hours
Digital Keystone Correction: YES
HDTV Compatible: YES (480i, 480p, 720p, 1035i, 1080i)
Special Features: 4-Way Manual Lens Shift, Direct Component Video Inputs, DVI-I Input, S-Video and a Single Composite Video Input, HDTV Compatible, Backlit IR Wireless Remote Control, Only 24 dB in Theater Black Mode, Wide Angle Lens, 1300:1 Contrast Ratio
Warranty: Three Year Parts and Labor, Quick Repair Program. 90 Days Lamp.
Included Accessories: Composite Video Cable, Backlit Wireless Remote Control, and Owners Manual
Specs: Sanyo PLV-Z2 Spec Sheet
Weight: (lbs.) 9.0
