MarkDavidson
- Jul 2, 2001
Proxima DP6850 XGA Projector --- 1500 Lumens!
Here is some sales stuff that I am cutting and pasting in: "The all-new Proxima DP6850 is bright enough to fill a room, versatile enough to fulfill your demanding needs, and affordable enough to fit your budget. Its superb image quality and advanced video capabilities make it a dependable tool in classrooms, conference rooms, and boardrooms."
It's in excellent condition, has the remote, and ways about 15 lbs. I am upgrading to a new projector.
I would prefer that the buyer is in Houston but am willing to ship. Buyer to pay actual shipping costs.
Below is a list of features and specs.
$2500 NOW $2225!! or equivalent trade.
Shoot me an email if you need details.
Mark Davidson
(Here are the features and specs)
1500 ANSI lumens makes it ideal for most conference rooms and classrooms
true XGA (1024 x 768) resolution and Fit-to-View display of VGA (640 x 480) through SXGA (1280 x 1024) supports full screen images from PCs and Macintosh computers
digital keystone correction makes it easy to project a square image whether the projector is placed high or low
flexible connectivity with ports for up to two computers and USB mouse to easily accommodate multiple presenters
high-quality video performance with picture-in-picture and support for most video formats
whisper-quiet (less than 40 dB), so your audience can focus on your presentation
motorized zoom and focus offers flexibility in projector placement, while digital zoom offers close-up views of selected items
Plug and Play user-friendly design offers quick, easy, and worry-free set up
PICTURE-IN-PICTURE
show video clips within your presentations
KEEP IT SQUARE
digital keystone correction displays a square image whether the projector is placed high or low
FIT-T0-VIEW®
digital scaling optimizes images of any resolution
TRUE XGA RESOLUTION
outstanding image quality and compatibility with most PCs and notebooks
BRILLIANT IMAGE
at 1500 ANSI lumens, it's perfect for classrooms and conference rooms
MAKES CONNECTIONS
two computer inputs accommodate multiple presenters seamlessly
DP6850 SPECS
Native Resolution • XGA (1024 x 768)
Resolution Supported • XGA (1024 x 768), Fit-to-View display of VGA (640 x 480),SVGA (800 x 600), SXGA (1280 x 1024),Mac (640 x 480, 1280 x 1024 )
Brightness • 1500 ANSI lumens
Contrast Ratio • 100:1 ANSI
Computer Compatibility • IBM PC or compatibles, Apple Macintosh
Video Compatibility • PAL B, G, H, I, M, N; NTSC 3.58 / 4.43; SECAM
Display Technology • 1.3" polysilicon LCD x 3
Number of Colors • 16.7 million
Input Sources • 2 computer, 2 audio, 1 video, 1 S-video, 1 USB mouse
Output • Computer RGB (HD-15), Stereo audio (mini-jack)
H-Sync Range • 15 - 100 kHz
V-Sync Range • 43.5 - 130 Hz
Bandwidth • 135 MHz
Horizontal Resolution (TV Lines) • 500 TV Lines
Keystone Correction • 20°, 20:1 upward, digital keystone correction
Projection Lens • Motorized zoom and focus. f = 49 - 64 mm, F/1.7 - 2.3, 1.3:1 zoom ratio
Projection Distance • 3.6 to 35 ft (1.1 to 10.7 m)
Aspect Ratio • std:4:3 - wide:16:9
Image Size • 2.0 ft to 24.3 ft (.6 m to 7.41 m)
Throw Ratio • 1.8:1 to 2.4:1 (image width: throw dist.)
Projection Method • front/rear, desktop/ceiling
Audio • 2 x 1-watt stereo
Remote Control • Full functionality remote with mouse control and laser pointer
Lamp (Life) • 190 watt UHB (1,500 hours to 50% brightness)
Dimensions • 11.5" W x 15.5" L x 4.7" H (29.1 cm W x 39.5 cm L x 11.9 cm H)
Weight • 13.2 lbs. (6.0 kg)
Power Consumption • 320 watts
Power Requirements • 90 to 132V / 198 to 264V (+/- 10%) at 50/60 Hz
Operating Temperature • 41°F to 95°F (O°C to 35°C)
On-Screen Menu Languages • English, French, Spanish, Italian, German, Norwegian, Dutch
Audible Noise • 40 db
Approvals • CE, UL, cUL, TUV, FCC Class A
Security • Kensington ® lock compatible$2500 $2500 $2500 s$2500/s
Mark Davidson
PICTURE-IN-PICTURE
KEEP IT SQUARE
FIT-T0-VIEW®
TRUE XGA RESOLUTION
BRILLIANT IMAGE
MAKES CONNECTIONS
DP6850 SPECS
Bandwidth • 135 MHz
