FS: FS: ZEKTOR HDS4 Component Video Switch (1 Viewer)
Patrick Zapatka
The HDS4 is an HDTV audio and video switch. The HDS4 is capable of switching 4 sources of component video, digital audio (coax and optical), and analog audio, all with the convenience of IR remote controllability. It's flexible inputs and passive switch contacts allow for switching of 5 wire video formats such as VGA (RGBHV), as well as reverse operation (1 source to 4 outputs).
FEATURES:
4 Inputs, 1 Output Up to four sources of HD component video, and one outputs. Video performance at 37MHz is -0.3dB (avg. of all channels). -3dB bandwidth is over 100MHz.
Passive Switching Design. Video and analog audio signals pass through Silver Alloy with Gold plating, relay contacts. The benefit of this is zero amplifier noise, zero gain or loss, and plenty of bandwidth for the upcoming 1080p signals. The impedance controlled design provides the same quality as a direct cable bypass. All internal signal lengths have been matched to eliminate any signal delay errors. All inactive inputs are 75 ohm terminated to reduce cross talk, and to greatly reduce the possibility of spurious noise pickup on any unused inputs. The passive design also allows signals to be routed backwards through the switch, allowing up to four display devices to be switched to one source. (Note: SPDIF and Toslink connections are not bi-directional.)
Component Video, L/R Analog Audio, Digital Audio on Coax (SPDIF) / Optical Digital Audio (Toslink) are available on each input.
Optical (Toslink) and Coax (SPDIF) are both automatically converted. When either input is active, both signals are available on the outputs.
The Left and Right Analog Audio inputs use the same passive design as the Component video inputs. This allows them to also be used for high bandwidth signals such as RGBHV or VGA (some adapters to RCA plugs would be needed).
Controllable using any Universal Remote. Control the HDS4 using any universal remote by selecting from a small list of existing manufacturer command codes, or by teaching the HDS4 to use any unused buttons on your existing remote. There's no need to use a learning remote control (though the HDS4 will work fine with one); the HDS4 can be taught to use any unused buttons on your existing remote control. (Remote control not included.)
Remote Control interface allows: Power Toggle, Bright/Dim/Auto Display Modes, Direct Channel Selection, Channel Up, Channel Down and for better integration with universal remotes with macro capabilities Power On, and Power Off are also available.
Auto Dimming Display. The LED indicator lights can be set to Bright, Dim, or Auto mode. Auto mode will fade the LEDs to half power after a channel is selected.
Full Size Metal Enclosure for better integration into your system. (17"W x 6.5"D x 1.75"H)
Rack Mountable, 1RU. (Rack mount ears available in black only, sold separately.)
Gold Plated Connectors used throughout design.
The unit is in perfect condition.
$150 Shipped via FedEx Ground.
