jimstark
- Jan 9, 1999
I am building three flexy-like racks soon (actually built one, a printer/scanner stand, today, out of ends left over from milling and some 1/2" threaded rods I already had). The one I have questions about is the CD rack I plan to build.
I'm using 6' sections of bull-nosed, 12" deep MDF. I have 5/8" all-thread, and I plan to space then 2" off center, somewhat set in from the edges, but close enough to support the CD jewel case. I also plan to drill a series of notches in the shelves, in which I will place a peg, just in case the CDs don't quite fill the shelf.
My plan is two rods on the end, two in the middle and two at the end. 6' rods, 8 shelves. Should hold about 1500 - 2000 CDs.
My first worry, of course, is tipover. Does this seem way too high for this much weight? Would it help to use a much wider, say 18 - 24" bottom shelf, so if it tried to tip forward, it simply couldn't?
I do plan to wire the unit to the wall...it's *never* going to be moved until I sell this house! That should prevent any severe accidents, yes?
I know this is is a rather unwieldy size, but I can't find a CD rack that holds more than 1000 CDs, and we already have 1200. Not to mention the bigger racks cost a billion and a half dollars!
So, flexy experts, does my plan hold water? Any problems or suggestions you can see?
-stark-
my gear: The Kenefick Home Theater
my movies: http://www.dvdtracker.com/~jimkenefick
-stark-
