Jay H
Home Improvement thread#2 for me today!
Fixing a screen door, has 2 hydraulic jack things on the top and bottom, the door is basically holds a screen or glass that currently is a screen (summer here).
It has two of those hydralic jacks, one on top and one on the bottom. The problem is that the door when opened and released, shuts very fast (especially with the screen) and then about a foot from closing, it finally slows down. I've tried adjusting both jacks (tighten the screw is supposed to slow the closure), however, it seems the screws have no effect other than to slow the closure rate AFTER the door closes to about a foot from the closed position. So in other words, the adjusting screw is not working for me. Is there any other option and if I bought a new $10 hydraulic jack, would that fix the problem. I looked at one of them today and it appears that the screw is the way to adjust the closure rate, but it doesn't seem to say whether the closure point is adjustable.
Any hints, suggestions? I know there are two points where you can adjust the jack (remove the pin, move the shaft, replace the pin kind of deal) but I don't know if that would help.... It keeps jabbing me in the back of the legs when I let go, I'd wish it would slow down and give me ample time to scramble into the door, especially if I'm carrying things like groceries...
jay
jay
