Hello all,
I have been lurking and searching old posts, but I can't find a solution for a pre-wired room. I will have 5 HTD HD-80 in ceiling speakers, an HTD center channel and a HTD sub. I have a Yamaha HTR-5840 that will power all of this. I understand how all of the wires would connect to the receiver, but the builder told me of a wire next to a light switch that would control volume. There is no plate where the wire would be, so do I take his word and cut a hole? There is a plate for all of the wires behind the TV.
I am not sure how the wires connect to the volume control plate. Do they daisy chain from the volume control knob to the plate by the receiver? The room was pre-wired for everything, I just need to know how the volume control connects between the speakers and receivers.
Dan
Dan
