Chris Rock
- Jan 10, 2001
I own a Netgear RP114 Web Safe Router, one that is on the "Compatible" list with XBL, or at least it is once you implement a certain workaround.
Well, when I got my kit, I followed the workaround and got connected. Then, without warning, I could no longer connect to games. I got a message saying that "my XBox could not connect to XBL". When I launch the troubleshooter, it completes the 4 connection tests and tells me that I AM connected.
I actually CAN connect directly (without my router), so I know the problem has to do with the Routed connection. I've been to XBox Tech support, and NetGear's website, and I've done all the troubleshooting I can think of.
My PC and my PS2 connect just fine from the router. The cable is not the culprit, either.
It looks like I'm gonna have to get a new router. Aaaarggghhh.
(Nobody out there can help me, can they? I didn't think so.)
