Neil_S
- Dec 2, 2000
Ok
The nice folks at Have Inc sent me a 1' sample of 1694a so I could see if it would be what I wanted. I want to use this for both speaker wire and interconnects.
When I stripped the cable, the first thing I noticed was the construction:
16 gauge copper core
Teflon insulator
Aluminum 'foil'
Aluminum weave
Outer insulator
Aluminum? Isn't aluminum rather... um... bad for high end audio applications? I was told that the 1694a was some of the most high end.
Would I be better to try and find something with a copper weave also? I want to make some interconnects and speaker cable that will last me for a while so I'm willing to spend the extra money on high quality parts. Is 1694a (or some other with aluminum construction) the way to go?
Thanks!
Teflon insulator
Aluminum 'foil'
Aluminum weave
Outer insulator
Thanks!
