AndrewAL
Grip
- Feb 8, 2004
I recently purchased the Sony KE-42TS2 Plasma TV...and I have a few questions.
1. The image is pixilated from even 6 or so feet away, moreso when it's in widescreen mode, which is predictable. I am using the cables that came with the TV and it is a regular program, not HD. Why is it somewhat pixilated?
2. What kind of cables should I get to optimize the performance at a fairly resonable price?
3. Does having Digital Cable make the image better than normal cable?
4. It says it has a: "Built-In NTSC TV Tuner," what does this mean?
5. "Input Signals: 480i, 480p, 1080i, 720p, Computer RGB." I think I understand, to a point, what the numbers mean, but my question is, why wouldn't you want to use the highest number of lines possible? Also, I've gone through the menus and cannot find any way to change this...probably a dumb question but oh well.
6. Finally, the menus do not let me switch the picture (contrast, color, hue, brightness, etc.) unless its on a mode other than standard (such as Living Room). Why is this? Should I watch in a mode other than standard?
I really really appreciate all of your help. Thanks.
