UGS with the wrong disc in it.
UGS doesn't have DTS on '82 cut.
What exactly is the difference between the 2-disc & UGS?
Which one has the full Doc.?
There's an extra John Williams/music bit? On which one?
There's stuff on the 2-disc that isn't on the UGS?
Alright boys and girls, it's time to leave all that fun behind us and talk about actual glitches on the discs.
Watched the '82 from the R1 2-disc last night with no problems. Had the typical slight pause at the layer change. Then I put in the '02 and searched out the layer change and found problems. It locked up/froze for a few seconds then eventually started back up at the beginning of the next chapter after skipping several seconds of the film. Went back and tried it several times with the same results.
Although my DVDP is an older Sony (DVP S360) this is the first disc I've ever encountered a problem with.
So, anyone else?
So, anyone else?
