Ryan*D
- May 15, 2005
Hey guys
I Need to find a projector for my HT room.
I was going to buy the Dwin transvision 4 but I like to keep my options open for other projectors out there.
First off is the Dwin worth it? Anyone own one? If so what do you think? Did something else bigger and better come out that you wish you had insted?
Next Is there something else out there that is just as good or even better for same or lower price? Around $5500?
If I do buy the Dwin can someone give me a link to a site I can order it from. I'm having a hard time finding someone carrying it.
Or links to other projectors that I should consider
Thanks for the help!
