Dvi input vs rgb input. (1 Viewer)
Tim Knapp
Hi,
For you htpc vets, how necessary is having a projecter with dvi inputs if using a htpc? Is it going to be that much better then just using the rgb input with a computer?
Tim knapp
stanrozenfeld
