Jeff_Hunt
- Mar 21, 2000
http://www.useit.com/alertbox/20011209.html
What do you guys think? I tend to agree with what he says there.
Selecting DTS audio on a DVD (when you aren't set up for it) will result in silence. If your player can't output the DTS signal: silence. If your receiver can only do DD, and it receives DTS: silence. If you have your player hooked up with the analog outputs: silence. (If your player has a DTS decoder built in, then it's a different story.)
Not on my equipment. If my decoder is set to Dolby Digital while playing a DTS DVD, then you will definitely hear something that can't be good for speakers. (I've tried while set at a very low volume.)
16x9 enhancment. Even if the movie is 1.33:1.
Okay, two questions.
First, you mean that the menu should be 16:9 enhanced, but NOT the movie itself, right?
Second, why? I can understand 16:9 menus for a 16:9 movie, for consistency's sake and what not, but why would you want a disc where the menus are encoded differently than everything else?
