SAY IT LOUD
- Jan 4, 2008
- TROY
Hi i have read that you can build the centre speaker box first then design the crossovers second is this true? . i can get the crossover professionally built I want to use the following listed.
1x 1" HDS Peerless tweeter T-S Parameters
Resonance Frequency fs 700 Hz
Mechanical Q factor Qms --
Electrical Q factor Qes --
Total Q factor Qts --
Force factor Bl -- Tm
Mechanical resistance Rms -- Kg/s
Moving mass Mms -- g
Suspension compliance Cms -- mm/N
Effective cone diameter D -- cm
Effective piston area Sd -- cm2
Equivalent volume Vas -- ltrs
Sensitivity (2.83V/1m) 93 dB
4x 6.5" HDS Peerless Phase plug mid woofers. T-S Parameters
Resonance Frequency fs 41.9 Hz
Mechanical Q factor Qms 2.41
Electrical Q factor Qes 0.42
Total Q factor Qts 0.36
Force factor Bl 8.2 Tm
Mechanical resistance Rms 1.83 Kg/s
Moving mass Mms 16.8 g
Suspension compliance Cms 0.86 mm/N
Effective cone diameter D 13.1 cm
Effective piston area Sd 135 cm2
Equivalent volume Vas 21.7 ltrs
Sensitivity (2.83V/1m) 87.8 dB
Ratio BL/√(Re) 3.4
Ratio fs/Qts F 122
Can someone please model a box for me?
Cheers Troy (I am a HT green horn but a quick learner)
Ratio BL/√(Re) 3.4
Ratio fs/Qts F 122
