KevinW
- Dec 11, 2000
I recently replaced my seriously aging Denon avr 1910 with the 960h. One of the music sound mode options is DTS + Dsur but I can’t figure out that it’s doing….or supposed to….
It might be that way out of the box, I'm not sure, but if you select to play a DTS soundtrack with Dolby Surround processing, then the next time you play DTS it'll use Dolby Surround and stay that way unless you select a different codec.Doesn’t Denon auto select processing to match codec? I thought this was a standard feature for the past 25 years? Or will it try and use Dolby to process DTS unless you manually tell it to decode DTS correctly?
