Darren Lewis
- Jul 17, 2000
I'm developing a MS Access database application for work, but I'm wondering about whether it's best done this way. Access is very powerful (when you get to know it), but I want to be able to distribute an application package and update it. Access seems a bit tricky to update the application once you've created it. I've split into frontend and backend databases, but updating the backend seems tricky as the user already has lots of data in it.
Presumably I can write some VB to update the table structure if needed, and then just distribute a new frontend?
What about using something like Delphi or Visual Basic to create a database app that doesn't rely on Access? Lots of these collector-type progs eg DVD Profiler seem to be written in Delphi.
I've no programming experience (apart from limited use of VB in Access, and use of PHP & MySQL in webdesign), so which of the two (VB or Delphi) would be a good one to learn?
I don't have the office developer's edition, so this is not an option.
Thanks.
Thanks.
