Leon B
- Feb 8, 2002
I have a sony STRDA555ES receiver which will crossover at 80hz when the speaker setting is set to small (Correct me if I'm wrong). I also have an old sony subwoofer (SA-W30) with the lowest crossover setting of 60hz and Polk towers (RT1000I). Since the Polks do not have a crossover setting, I assume everything below 80hz is being sent to the powered woofers, however, if the sony is set to 60hz, does that mean everything between 60hz & 80hz is lost on the sony?
