Justin_Terpstra
- Mar 8, 2001
I need help, or suggestions w/ my crossover frequency.
I have:
- Marantz SR-7000 reciever
- Sound Dynamics RTS-9s mains (dual 6.5" + tweeter)
- Sound Dynamics C-2 center (dual 5.25" + tweeter)
- Paradigm Mini Monitors rear (6.5" + tweeter)
- Velodyne SPL-1200 sub
The reciever has a fixed crossover of 100Hz. Currently I have everything set to small and the sub crossover off so that its basically set to 100Hz off the reciever. All information 100Hz and below gets routed to the sub ....
Do you think it would be better to run the mains as large and then use the sub crossover at some frequency, something like 65Hz or so?
In doing this I think the sub only gets information from a true LFE channel after that. I would have to swap the sub to get its information from the R+L outputs and set the reciever setup to "NO" sub.
Thanks ....
I have:
Thanks ....
