NolanJ
- May 1, 2004
Hello,
I'm in need of a PIP splitter, in order to get the PIP on my HDTV television to work.
Currently I have my HD Cable Receiver connected to my TV with a DVI Cable.
Based on the research I've done, I need to split the cable wires, so that one end goes directly to the television and the other end goes thru my cable box to the VCR.
Question 1) Is this correct?
If this scenario is correct, I have a problem because I don't have a VCR, and my DVD player is connected thru component cables to the TV and thru a optical audio cable to my Onkyo receiver.
Question 2) What must be done in order for my PIP to work correctly?
Question 3) Will I even be ABLE to get my PIP to work correctly?
