Hello All,
I have a clarion control deck, clarion cd changer, sony xplod 444 watt 4 channel amp, 10" 4 ohm MTX Pro 500 watt max sub in an ported enclosure w/ a 4" port, and 2 5" 4 ohm MTX Pro speakers. I have some other home speakers that I may use to complete the system.
I would like to convert these to use in my home for use in home theater. I am planning on building a new enclosure for the sub and building enclosures for the other 2 speakers to fit in with my home decor.
I have already bought a 10 amp power supply to power the cd changer, amp and control deck (works good).
I have also already bought 3/4" birchwood to do the enclosures. I had read one sight that suggested this but since then the more I have read has suggested 3/4" MFB.
My questions are:
Would I need to purchase a receiver to feed the audio to the car amp or should I just feed it directly from the source?
When building the sub enclosure, could I use the MFB to build the sub, then use the birchwood for an overlay to give a better look? If so, what widths should i use of both or would 3/4" be fine?
If I build the new ecnlosure to match the cubic feet (w/ different dimensions) of the original one and the port too, should I receive the same performance from the sub that the original box gave?
Is birchwood alone fine to use for the other two speakers?
Thanks for all your help.
My questions are:
