Hanah
- Oct 21, 2001
Just didn't know where to post, and I am sure one of you guys will know!
Hmm...
First I have one Dolby Prologic Amp (2 fronts / 2 mono rears / centre)
2 B&W 602 S2s and Audio Pro subevidence sub.
Problem is that my amp doesn't have the 'sub out' (6year old model), thus I cannot use the low pass, but have to use the high pass. [or is there a way to use low pass?]
If I use the low pass, I can use the cross over knob between 23 and 100 hz.
But if I use the high pass, the B&Ws only gonna get above 100hz (its set).
Is there anyway that I can connect both speakers and sub to an amp, rather than connecting speakers through the sub then sub to amp?
I want bass out of both speakers and the sub. And freedom to control my low pass frequency.. (I want to set it to 60hz) 100hz produces muddy bass for my taste.
I can still set the sub at 60hz, (with high pass), but then my speakers will only produce anything above 100hz, and I will have a gap between 60 and 100.
If anyone can help me out, please do..!!
Thanks in advance.
[Edited last by Hanah on October 22, 2001 at 07:03 PM]
Hmm...
Thanks in advance.
