Joe*H
- Aug 26, 2004
guys I am using a def tech model c1 with klipsch sf3 fronts and I find that I have to keep the center turned way up to at least +5 so that I can hear it over the fronts. I am using a yamaha 5740 receiver( for now). I dont know the specs on the sf3 but the center is as follows
Dimensions: 6.75" H x 19" W x 8.5" D
Frequency Response: 45hz - 28khz
Efficiency: 90 db (1 watt/1meter)
Nominal Impedance: Compatible with 8 ohm outputs (6 ohm
average)
Driver complement: 2 x 5.25" cast basket bass/midrange
driver, 1
x 1" dome tweeter
(later models had a 1" aluminum dome
tweeter)
Recommended Amplification: 10 - 200 watts per channel
I figured that this must be a set up problem or that I need a better receiver. anyway if you have any ideas please let me know. thanks
average)
driver, 1
x 1" dome tweeter
tweeter)
