carver 'cube' amp to drive sub? (1 Viewer)
Jim J
I'm not sure if this should go in 'Speakers and Subwoofers' or Receivers/Separates/Amps. Anyway...
Anybody out there using one of those Carver Cube amps to drive your sub? I think they are 200w into 8ohm
I like the idea of the quiet and the form factor.
I have a SVS 20-31CS+, but am interested in any model feedback
tia
Darrel McBane
I used a Cube to drive my single 20-39. It puts out like 500wpc@4Ohms. I also blew my driver in the 20-39 using a Cube while listening to TPM DVD pod race. Make sure your driver can handle that much power. I'm now using two channels from a Rotel 1095 ( 300wpc@4Ohms ) to drive my two 20-39 subs. The newer SVS models can handle 500watts I believe and would work very well with the Cube. But, a single 20-31 even properly calibrated would be asking for trouble. The Cube is a quiet and cool running amp and would work for a lot of applications in HT. But bridged it puts out considerable power.
Hope this helps some.
Jim J
Helps a lot, thanks.
I could always use just one channel. I'm getting fine results using a receiver channel now, which I estimate is high 100s into 4ohms.
Thunder
