Dustin B
- Mar 10, 2001
I used an AVA250 with the Tempest sub I built. Theoretically I can use all of it's power output as 250 watts is what it takes to push the Tempest in my enclosure to Xmax. Have I come close to using the full 250 watts, I doubt it. But like the fellow above says, it provides the headroom. The AVA250 is capable of pushing my sub to it's clean output limits, but isn't capable of bottoming the driver. So no matter what I throw at my sub I shouldn't have any problems.
The bigger benefit of the AVA250 is unlike most other sub plate amps it has no boost in the 30-35hz range which can limit the power handling capabilities of your sub. Plus it has a rumble filter (2nd order high pass filter centered on 18hz). Without it, below 16hz it would be possible to bottom my sub. Don't know what would have the sound info to do that, but still it keeps my mind at ease knowing that it should be impossible to bottom my sub.
