kanian
- Oct 20, 2003
What speaker cables whould you recommend for my system: receiver H/K AVR 525 and mains B&W DM 603. Do you think I should bewire the speakers? Thanks for help. Adam
I went by the reccomendation of a trusted associate...at least bi-wire the mains and center. After all, B&W put the crossovers in there for a reason.Can you elaborate on that for me?
IIRC, the crossovers are always used. Life would be very unpleasant for the tweeters and mids if not.
When you remove the jumpers and bi-wire, your jumper is now the two pieces of speaker wire, connected at the speaker terminals of the amp, rather than a 1 inch piece of brass at the speaker.
How this can "improve" the sound is a subject of debate. I tend to subscribe to the view that vendors put dual posts on their speakers so as to appeal to the tweaks.
And new speaker wire cured a hiss problem? I sure would like to understand how an inert piece of copper could cause/cure hiss.
But, if you got good reults, then why ask why?
BGL
When you remove the jumpers and bi-wire, your jumper is now the two pieces of speaker wire, connected at the speaker terminals of the amp, rather than a 1 inch piece of brass at the speaker.Shhh!!!
And new speaker wire cured a hiss problem? I sure would like to understand how an inert piece of copper could cause/cure hiss.Geez, call me a liar why don't you? It did in fact make a big difference, and yes, an inert piece of copper or silver or whatever material you choose, can make a big difference. Any signal is subject to attenuation and interference, depending on the type of "inert" material used and its type of shielding, the signal can travel at faster/slower speeds or experience significantly less/more attenuation and/or interference. . My rears happened to have a fairly long run (50ft.) and were exhibiting a hiss. After replacing the wires the hiss was gone and the sound was much clearer. If it did not matter what type of wires/cables you used, there would be no market for them. Yes, some companies prey upon the idea of this (Monster for example) and tend to over-charge you. In the same respect, do you use the interconnects that come with your components, or do you upgrade to a better, composite/component/digital/etc. cable? Why have gold coated connectors? Why not use aluminum foil or tin?
While I believe there are differences in wires, I also believe in the theory of diminishing returns...will quality equal cost as they both rise, no...you've got to set a point that you feel comfortable at and don't purchase beyond that. If your point is home depot wire, then fine, but don't discredit the ability of different types of wire to carry a stronger or cleaner signal.
Geez, call me a liar why don't you? It did in fact make a big difference, and yes, an inert piece of copper or silver or whatever material you choose, can make a big difference. Any signal is subject to attenuation and interference, depending on the type of "inert" material used and its type of shielding, the signal can travel at faster/slower speeds or experience significantly less/more attenuation and/or interference.Nope. Just want to understand the phenomena. If you heard a difference, than there was one, but I would like to understand it, thats all.
Attenuation (due to higher cable impedance) would result in diminished signal, thus diminished acoustic output given the same output level from the amp. But it would not cause any hiss, and a slight increase in amp level would compensate. For a speaker cable of normal length in a typical room, you are talking differences from cable A to cable B of perhaps a few ohms.
Increased capacitance would cause a roll off of the high frequencies, but again, the amount involved from one cable to another should be low enough to be inaudible. If not than the cable that is doing the most high frequency attentuation was certainly a very poor design.
As for shielding, speaker wire is unshielded because the levels involved normally dwarf any RF noise a given run of wire would pick up.
Any hiss issues that I have dealt with normally occur due to poor pre-amp/processor design, or excessive gain somewhere in the signal chain.
But as I said, I never doubt when someone says they hear (or don't hear) something. But I do want to understand why.
I subscribe to the viewpoint that there is no affect without a cause, whatever that may be.
And I would still like to understand your thoughts on bi-wiring WRT crossovers or lack thereof.
BGL
Yes, some companies prey upon the idea of this (Monster for example) and tend to over-charge you.I'm not sure why people say this. In the realm of designer wire, Monster is one of the least expensive making a relatively decent product.
As for the hiss, there was probably another reason for the removal of the hiss than the wire itself, unless the wire was damaged or was the incorrect ga. for the run of 50' for the impedance of the speaker it was powering.
Speaker wire CAN pick up noise if it is run right next to high voltage lines. When my friend remodeled, he had this happen with his in wall wiring for his rears. The contractor had to redo the wiring.
I too am of the mind that interconnects and wire influences the overall sound of a system, though they are much lower in the grand scheme of things that should be paid attention to when building a system. They should be of a relative quality to the rest of the system, and be chosen for synergy with your gear, which can be difficult.
