john seitz
- Apr 1, 2004
which ones to keep?
I bought a set of Boston CR95 (fronts) and a Boston CRC (center) will be useing a Mirage AVS 100 for rear suround and a Mirage FRX-8 sub
or
I also bought a Bose AM10III kits for $669 at CC (price match of 699 at sears plus 10%)
I have a Yamaha HTR-5250 110x5 amp
the reason for the new speakers is my AVS-200 center is shot and the sound is "flat" I figured the deal on the BOSE was too good to pass up... then again I only paid $560 for the three Boston speakers.
What ones should I keep? The Bose wireing seems a little Odd to me and a loss of quaility or I'm I just over reacting? And will the mix of mirage and boston be bad till I can afford all Boston?
if it matters the HT room is/was a converted spare bedroom that is on the small size - about 12x16 with a Toshiba 42" widescreen rear projection TV.
thanks in advance...
or
