afviper
- Oct 15, 2006
- Igor
I recently bought a BIC H100 with a non working amplifier. Would it be a good idea to replace the amp, and driver, or should I just get a new amp, and keep the driver. If I was to replace the amp and driver I would probably get an amp that is $100-$150, for example the partsexpress 300W, and 500W Bash amps. For the driver I am not sure, but I would prefer to spend around $100. Here is a link to the BIC H100 specs if you need them http://www.acoustechspeakers.com/sho...pe=8&spkrID=26
If the performance increase is significant I would definitely spend the extra $150-$200 for the upgrade, but if it is a small increase in quality I would prefer to save the money, and just buy a replacement amp. I understand the box is a lot smaller than most DIY subs, so that will probably limit the performance if I choose to upgrade. I was also thinking of sealing the enclosure, although that might make this a little big for a 12" sealed sub.
