ScottMc
- Jul 8, 2003
Since the search function isnt working at the current moment, I am curious to hear what you all think is the best bang for your buck DVD player under $300?? I am curious to what you all think about the Panasonic RP91, since it has come down to $299 at Crutchfield?? I will be replacing a Toshiba SD-2108.
Thanks.
Thanks.
